Thread: Select only outside/visible polys?
    Aug 2014
    Indiana
    284
    I have an object with internal geometry but I would like to apply a separate texture to only the outside geometry. Is there a way to select only polys on the outside of the object easily? I'm using lasso tool in the perspective view and that works well for simpler objects, but complex objects can take some time.
    italy
    1
    hi! try select by normal script, you can find it here http://www.pixsim.co.uk/
    hi, it can be kinda tricky actually,
    i use these methods, in addition to other methods (expand) (select by normal)
    yes, included in LW11.5 by default
