Thread: Bandglue
    May 2003
    Braham, Minnesota
    29
    Bandglue
    Has anyone noticed how slow bandglue has become with 2018?
    I have the 3rdpowers plugins and there banglue is a dream compared to lightwaves.
    Aug 2016
    a place
    1,199
    yeah, i think it changed how it worked or seems to have changed. wonder if the old one can be added to 2018?
    Feb 2018
    US
    4
    It looks like bandglue is half-undressed... before, everything happened under the hood. Now, you select in polygon mode (as before), LW then switches to edge mode, deletes loop, and has to be switched back to polygon mode manually. Maybe it needs a few more lines of code?
    May 2003
    Braham, Minnesota
    29
    Something is definately wrong with it. They messed something up. I'll stick to using my 3rd power plugins but Newtek needs to address modeler eventually. Thank god for plugin community!
    May 2003
    Ohio
    412
    I'm not seeing speed issues but the switch to edge selection mode afterwards is certainly a nuisance.
    Aug 2016
    a place
    1,199
    dont fix wot aint broken. on the other hand... rounder, UV tools, CC subdivs, yada yada
    May 2003
    Braham, Minnesota
    29
    Also running into a problem this morning with the mirror tool. Mirrors the poly's but leave's some flipped and leaves them also non planer.
