Thread: Firmwareupdate
    Jan 2014
    Germany
    32
    Firmwareupdate
    I wanted to update the firmware of the PTZ1 yesterday. There was a power failure. I can not reach the camera anymore. What can I do?
    Tricaster 460AE2 + 460CS
    3 x JVC GY-HM890
    Panasonic AW-UE70
    Newtek PTZ1 | Newtek Spark HDMI | Newtek Spark SDI
    Jan 2014
    Germany
    32
    Hello,
    all back. I was able to access the screen menu over sdi again and make the settings. All works fine with the new firmware.
    3 x JVC GY-HM890
    Panasonic AW-UE70
    Hi Rabbit!
    How do you like the new camera? Is it working for you so far?
    Andrew
    Tricaster 460AE2 + LC-11
    Rack: Router, switch, backup encoder, captioning devices, audio mixer , etc
    Cameras: Sony FS700, Z150, NX5, NewTek PTZ1, Spark
    http://reddogrecords.com
    Jan 2014
    Germany
    32
    Hello Andrew,
    the camera is ok, quality of the pictures is ok if you have a good network connection. The camera is also easy to use. The connection to the camera can also be made well with the studio monitor. However, I always have problems using the camera on the TC460. Although Camera and Tricaster are in the same network. I'm unsure if I made all the settings right on the Tricaster. Have you seen a step by step guide to the integration of the camera in the network to use with Tricaster?
    Hartmut
    3 x JVC GY-HM890
    Panasonic AW-UE70
    Apr 2008
    Racine
    1,021
    In order for TriCaster to see the NDI signal from camera, you MUST install the NDI HX driver on the TriCaster - please do that if you had not previously
    https://www.newtek.com/ndihx/products/
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: PTZ Optics 20x SDI
    Jan 2014
    Germany
    32
    Hi Jeff,
    I do so - the driver is installed. But it is strange - I put the camera to one network outlet - I canīt see the camera on the Tricaster; I put the camera to a other network outlet in the same vlan - I can see the camera on the Tricaster.
    Other question: Is there also a Access Manager necessary on the Tricaster?
    Greetings
    3 x JVC GY-HM890
    Panasonic AW-UE70
