Thread: TC1 - 4k input options
    Aug 2016
    northern CA
    4
    I have a TC1 with the NC1 studio i/o module.
    Can someone please advise, will the AJA ha5-4k (https://www.aja.com/products/mini-converters/ha5-4k) work to convert 4k HDMI to quad stream HDSDI for input into the NC1?
    Is that the sort of cheap/baseline option? What are other people doing to get 4k in?
    Thanks!
    Apr 2008
    Racine
    1,020
    I don't have the AJA HA5-4K myself, but upon getting the TC1 months ago I did my research and that's the AJA unit I had also come up with as a solution. Another option is to use a 4k capture card in a PC and convert to NDI with the NDI Connect app, and the NDI will go direct to TC1 without the NCI in the path.
    Jeff
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: PTZ Optics 20x SDI
    The AHA HA5-4K has the correct specs. You need the HA5-4K set to output in Quad-Link using the Square Division Quad Split method of signal transport to get the signal into the NC1 IO operating in UHD Quad-Link input mode.
    Key Accounts Sales Engineer
