Results 1 to 15 of 27
Thread: Products Test renders using lightwave 2018 PBR and !!!
    PC Specs:
    Processor: Intel (R) core (TM) i7-3930K CPU @ 3.20GHZ (12CPUs), ~3.2GHZ
    Memory: 32768MB RAM
    GPU: NVIDIA GeForce GTX 560Ti
    SETTINGS:
    GI enabled Interpolated Default - Sample Backdrop is checked - NO ISG Sampling- One distant light (1.5Lx) with angle 15 degrees and 8 samples - 1 back Area lights (10lx) 4 samples - 2 Rim Area Lights (35lx) with slight blue tint 4 samples.
    All renders are straight from Lightwave no Photo manipulation or editing is done.
    Color space: SRGB Default from drop down
    Render Time 10.32 Minutes
    Render Time 8.10 Minutes
    NO NOISE REDUCTION USED
    Scene was transferred from LW11.3 - shaders were converted from standard to BSDF using the Convert Layered to Principled node command inside the surface editor.
    Old scene didn't use GI just Area lights and a dome light with soft reflections enabled for surfaces.
    Render Time 16.03 minutes
    Models are CatmulClarck SUBDs level 3 - 2,060,997 Polygons in TOTAL
    MY 2 CENTS:
    SIDE BY SIDE the new 2018 is superior in quality compared to 11.3 to 2015 plus the whole application feels very snappy, even in modeler manipulating large number of points is way faster than 2015.
    Rendering time is excellent but requires a small learning curve to get up to speed.
    View-port FPS is UP by almost 40 percent depending on your scene.
    Picking a Model from the scene to be used for surfacing PREVIEW is great.
    Presets are straight forward.
    Lights are well implemented . Easy to know what you are expecting if you have real life experience in photography or similar. (wish the color, intensity and object exclusion would work with multi-selection)
    You are not giving the most important settings : )
    Adaptive Sampling Min/Max?Threshold ?
    Reconstruction Filter and Pixel Radius ?
    guy rabiller | radfac founder/ceo | raa.tel | French Lightwavers & Studios List
    Super Member Snosrap's Avatar
    Aug 2004
    Ohio, USA
    4,752
    Very good Ali! Just clicking back and forth between the 11 render and the 2018 render it is night and day different. The 2018 looks real whereas the 11 looks more like a really good Illustrator image. I do think though the plastic caps could be improved, but really nice overall.
    grabiller
    2018
    Min:5 - Max:20Adaptive Sampling ON Threshold :0.01 Filter Radius :0
    11.3
    Min:1 Max:15 Adaptive Sampling ON Threshold :0.01 Filter Radius :0 Reconstruction filter: Classic - Sampling Pattern: Low-Discrepancy
    Snosrap
    Thank you
    Registered User samurai_x's Avatar
    Jul 2015
    lalaland
    1,016
    Can you post both scenes?
    Quote Originally Posted by ali kassem View Post
    ../.. Filter Radius :0 ../..
    !? Now that's interesting.
    What led you set this particular value for this parameter ?
    samurai_x
    Sorry can't do, I'll see if it is possible to provide a different product with the same setup.
    grabiller
    I always start with the Default and this value is the Default.
    To teach is to learn.
    ________________
    www.alikassem.net
    Jul 2015
    lalaland
    1,016
    Ok. Surprising how the lw 11 render looks so bad. Like scanline render in 3dmax in the old days.
    Sure it can be a lot better, better results are guaranteed if you invest more time tuning surfaces.
    I was just showcasing how easy, straight forward and predictable the new BSDF Material and PBR are.
    ________________
    www.alikassem.net
    Testing DOF and Volumetrics
    3m 45s
    min:5 max:35 samples.
    Still needs refinement but for the time frame its great!
    Conductor and BSDF materials are used.
    3m 38s
    went with all BSDF materials no Conductors and I limited the dynamic range to 0 and 1
    ________________
    www.alikassem.net
    Apr 2016
    Barcelona, Spain
    396
    3m 45s
    Great!
    English is not my native language so please be patient.
    Salvador Ureņa
    http://urenasalvador.wixsite.com/portfolio
    8 volumetric light samples
    10 to 40 with adaptive sampling
    No DOF
    Very Very clean Volume light!!
    3min 29sec
    - - - Updated - - -
    Asticles
    Thank you.
    3min 32sec, love the rays. will be switching to 2018 for this project it's a no brainer.
    ________________
    www.alikassem.net
    Apr 2016
    Barcelona, Spain
    396
    How are you doing the bevel?
    Salvador Ureņa
    Bevels are done in modeler using rounder and cleaning overlapping edges, tedious but worth it. (waiting for an edge shader).
    ________________
    www.alikassem.net
    May 2007
    Belfort, France
    1,687
    Wow, we start getting really nice renders, now. Great job.
