Thread: Casting an iPhone screen with NDI
    USA
    303
    I haven't come across the info I'm looking for, maybe someone can help.
    I don't want to use the iPhone as a camera, I want to cast the screen to
    our 460 over NDI, is this possible? What needs to be put on the iPhone to
    Make this work?
    Thanks in advance.
    You have to use the AirPlay feature on the iPhone to get the screen sent out, then take that into a system that will turn it into NDI. There are two solutions I know about.
    The first is NewTek Connect Pro. It has AirPlay receiving built in. https://www.newtek.com/connect/connect-pro/
    The second method is to use NDI Scan Converter with an AirPlay receiving application like AirServer. I've documented this workflow here. http://kanelp7.wixsite.com/kanesworl...into-tricaster
    USA
    303
    Thanks Kane!
    I'll give it a look.
    You're always coming to the rescue.
