Results 31 to 45 of 46
Thread: Honda cb1100
  1. #31
    Frequenter
    Munich
    240
    Absolutely amazing, Dirk!
    I assume you have the real thing at hand? Or are you working solely with reference photos?
  2. #32
    Dirk Steffens aka Luke Boubsteve's Avatar
    Dec 2015
    Germany
    326
    Quote Originally Posted by fishhead View Post
    I wish I had the machine ... I only model with reference photos and watched some youtube videos to the motorcycle, from the videos I also take screenshots ... I do that to understand the shape of the objects until I realize it.
  3. #33
    Dec 2015
    Germany
    326
    Cooling
    ...i did the cooling system today
ID:	139992   Click image for larger version.
ID:	139993   Click image for larger version.
ID:	139994   Click image for larger version.
ID:	139995   Click image for larger version.
ID:	139997   Click image for larger version.
ID:	139998   Click image for larger version.
ID:	139999   Click image for larger version.
ID:	140000   Click image for larger version.
ID:	140002   Click image for larger version.
  4. #34
    Dec 2015
    Germany
    326
    fix
    some errors fixed and some edgeloops added to the cooler
  5. #35
    Barcelona
    1,665
    Fantastic thread. Keep the captures coming!
    Salut!,
    Allabulle.
  6. #36
    Dec 2015
    Germany
    326
    litle Updates today
    thank you very much allabulle...
    a few litle Updates to the Zylinderhead, Electriccase between carburettor covers, Oilfilter and the rear-wheel swing.
ID:	140032   Click image for larger version.
ID:	140033   Click image for larger version.
ID:	140034   Click image for larger version.
ID:	140035   Click image for larger version.
ID:	140037   Click image for larger version.
  7. #37
    Dec 2015
    Germany
    326
    Footrest
    going on with modeling...
ID:	140080   Click image for larger version.
ID:	140081   Click image for larger version.
  8. #38
    Dec 2015
    Germany
    326
    Footrest and rear breakpedal
    footrest, and rear break pedal segment complete...next i will go to the spokewheels
ID:	140098   Click image for larger version.
ID:	140099   Click image for larger version.
ID:	140100   Click image for larger version.
ID:	140101   Click image for larger version.
  9. #39
    Frequenter
    Munich
    240
    Clearly a fan! :-)
    Out of curiosity: how does modeler bahave with this insane amount of subpatches?
    ______________
    lorenz
  10. #40
    Dec 2015
    Germany
    326
    Spokewheel
    Clearly a fan! :-)
    thank you, oh the Modeler is doing well so far...it is still fast enough even at Subpatch level 5 all geometry.
    Spokes rear wheel done so far...they need the clamping screws, but on the way...
ID:	140108   Click image for larger version.
  11. #41
  12. #42
    Dec 2015
    Germany
    326
    tire first try
    first try modeling the tire. Maybe i will do it a second time with lower poly, but the technique to model the tire tread as a flat template, bend this piece around x and z axis, clone it with the array tool around the pivot and connect the pieces together works fine so far
ID:	140125   Click image for larger version.
ID:	140126   Click image for larger version.
ID:	140127   Click image for larger version.
ID:	140128   Click image for larger version.
ID:	140130   Click image for larger version.
ID:	140131   Click image for larger version.
ID:	140132   Click image for larger version.
ID:	140133   Click image for larger version.
  13. #43
    Dec 2015
    Germany
    326
    better tire
    i did a sketch to plan the Meshflow first.
    http://www.3d-ring.de/3d/groupware/p...capture_10.mp4
ID:	140138   Click image for larger version.
ID:	140139   Click image for larger version.
ID:	140140   Click image for larger version.
  14. #44
    Jan 2011
    Seattle
    295
    Thanks for doing these threads. They are inspiring.
    By the level of detail and accuracy you put into it, I realize you may want to model every bit, for the challenge. That is understandable. Just wanted to mention it would be easy to get a fully realistic render of that tire with just a good texture set. It seems like you are running into exactly why it is usually done that way. It is a lot of geo just to add a few indents. If you plan to 3D print that is another story. Just my 2 cents.
    It would be cool to hear your basic approach / thought process, when starting a new part. I find the hardest part of modeling for me is often figuring out the best starting place. One that doesn't cause you to regret it several steps later, as you realize you should have started another way. Interested to hear if you have developed a philosophy to break down the best approach for each part, or if you just play it by ear.
  15. #45
    Dec 2015
    Germany
    326
    thx for your reply. Yes, you are right, the goal for me is to learn solving problems while modeling, without the use of plugins, or looking for software like modo and mesh fusion. its my own challenge to think it in 3d. As you can read at the beginning, my goal was to learn subpatch modelling and create clean meshes with good polyflow and avoid n-gons and tris. So because it is not a project for any client i will do this. When modelling is done i create a bumpmap in addition, to have more Options while rendering, so i know, that this is a easy way to realise the , but not my goal, as i said.
    I know too, that the things i show here are not new to the most menbers here, but its a good way for me, to document the steps of my projects. Maybe this will go on to some tutorials one day, to better transport how i think things befor i begin to model. But i can say in most cases, i think about the Object, what is it in simple geo. and the biggest, or the main part of the simple geo -a box, or disk for example- is the starting point. In more complex situations some times i begin with a single quadpatch and extrude it along the longest axes. Some times i have (i think you mean this) more possible solutions and i have to try out, and some times i have to do things new, because of a better idea maybe...so i am inthere 100% and think abot it day and night , but this is the pure fun to me. So let me say again, yes there are ways to realise some things easier, but its my own challenge to learn how to solve problems.
