Thread: Lifetimes of params and return values from NDI SDK (C++, windows)
    Sep 2017
    UK
    10
    Hi all,
    Just wondering if there were specific guidelines for lifetimes of the string/struct params and returned structs with the NDI SDK?
    Example #1:-
    Code:
      Router(const std::string &name, const std::string &groups = "")
        NDIlib_routing_create_t params;
        params.p_ndi_name = name.c_str();
        params.p_groups = groups.c_str();
        instance = NDIlib_routing_create(&params);  // Is it safe for the 'params' struct to go out of scope now? What about the char array pointed to by p_ndi_name
    Example #2:
    Code:
    const NDIlib_source_t* p_sources = NDIlib_find_get_current_sources(instance, &no_sources);
    How long is p_sources valid for (presumable the caller shouldn't free() it) - and is this thread-safe?
    Software Engineer
    Jul 2006
    San Antonio, TX
    9
    Quote Originally Posted by roddyp View Post
    That is correct.
    It'll be valid until the next call to NDIlib_find_get_current_sources or NDIlib_find_destroy, so probably not thread-safe if you're using the same instance across multiple threads.
    Brian
    Sep 2017
    UK
    10
    Quote Originally Posted by brianbrice View Post
    Great - thankyou!
