Results 1 to 13 of 13
Thread: Setup
    Apr 2008
    Racine
    1,032
    Setup
    Following the Quick Start Guide for the camera, it said that the NDI Studio Monitor software was supposed to get installed with the NDI HX drivers. It did not. Tried uninstalling/reinstalling, no luck. Finally went to Newtek.com and downloaded NDI Tools Pack and got NDI Studio Monitor from there and then it worked fine.
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
    18,070
    Did you do this on a TriCaster? (If so, that explains why it wasn't installed.)
    Apr 2008
    Racine
    1,032
    Yes, TC1. My bad, didn't have another means of enabling camera at the time.
    Jeff Pulera
    18,070
    No worries. Although the basic 'quickstart style' docs make scant mention of it, you can do all of the same things using TriCaster's input source selection menu without loading Studio Monitor on the system.
    Apr 2008
    Racine
    1,032
    Had to update the TC1, didn't have the Configure button available originally. All good now, thank you!
    Jeff
    Jeff Pulera
    Apr 2008
    Racine
    1,032
    Unfortunately, all is not good...yet. I get the camera image in Studio Monitor and can also control camera there, works great. I open a TC1 Session and can get the camera image in Input 1 via NDI and also have the PTZ Control set to NDI, but have NO CONTROL over camera. Nothing. Not via the mouse-driven tools in PTZ tab, or via Control Panel joystick. I have a lot of experience using RS-232 cameras with this same machine, so not my first attempt at PTZ.
    TC1 was just updated to 6-0-170815, and camera firmware updated to VHR104h, and I read the camera manual cover to cover. What am I missing here to control PTZ from TriCaster? Just.Not.Working.
    Jeff Pulera
    18,070
    If the connection type is set to NDI, it should just work - without any configuration. If it's not, I'd suspect some sort of network issue, not sure where to begin ... maybe at the Firewall settings.
    Jun 2017
    Stockholm
    10
    Hi Steve & Jeff,
    I can confirm I have the exact same issue both the TC1 and VMC1. I have never been able to control the PTZ cameras at first start in either TC1 or VMC1. I have submitted a Fogbugz case on this.
    I found a workaround:
    1. Open the input settings tab for the Ptz camera
    2. Change the input source to any other NDI source
    3. Change back the source to the Ptz camera again
    After these 3 steps the PTZ controls should work again.
    //Martin
    (Tested and reproduced in both new and old projects. Newtek PTZ Firmware: VHR104h. VMC1: 170815, TC1: 6-0-170815. Ptz control from studio monitor works fine all the time though)
    18,070
    This sounds very much like a weird bug that I overheard being discussed while passing through QA late yesterday. It is now marked resolved, and I would expect the next release to include the fix. (If anyone really needs this in a hurry, they could email QA and ask for a beta).
    Apr 2008
    Racine
    1,032
    Martin,
    Thank you for sharing your workaround - that did resolve the issue. Will look forward to the update to fix it more permanently.
    Jeff Pulera
    Jun 2012
    Switzerland
    88
    Hi Steve,
    can you confirm I should be able to access the NDI camera webpage from the TC1 ? Control is working , picture is working, but I can't access the detailed settings of the camera... I guess Studio monitor is needed to know the IP adress, but as above, I can't get it installed on the TC-1 .
    18,070
    Hitting the "Configure" button (located at right beside the Source selection menu when an NDI device is selected) should pop up a browser and open the device's webpage. You do not need to enter an address, this should be automatic.
    Oct 2013
    London
    9
    Just updated to the lastest firmware on my HDMI mini and the PTZ camera - but it didn't do a thing and I'm still having the same issues - as in I can see the NDI feed fine, I can open up the devices webpage and control the camera that way - but I just can't control the PTZ in the Tricaster software - I have 4 of these sitting here looking really pretty but not a lot of use - we can control our PTZ optics fine via IP address and AE
    I've switched off any Windows firewall, tried changing the network between - home, public and work - all to no use
    The NDI feeds are great (we love our sparks) but the control of the PTZ cameras is a nightmare
