Hi all. I'm having a bit of a problem with one of my NDI receivers. I have to machines, let's call then A and B. The idea is for A to send a video to B, the problem is that B can't connect to the sender.
I tried it with test pattern on A and NDI Monitor on B. The monitor recognizes the sender but when I click on it it just shows "Connecting..." If I run the test pattern on B I can see it from A and B.
I've tried disabling firewalls, changing the ports of the applications I'm running so they wouldn't crash with NDI's, modifying network settings and sharing options, and some other stuff.
I'm really baffled at this point. Any ideas you might have are more than welcome.
