Results 1 to 2 of 2
Thread: Multicast on V3 SDK
    Aug 2017
    France
    5
    Multicast on V3 SDK
    Hello !
    Does anyone now if we can activate the multicast option of the SDK v3 on linux OS ? the AccessManager Tool is not available on Linux.
    Thanks to anyone by advance !
    I also did not found way to use multicast on linux.
    Access Manager tool just sets key in windows registry (HKEY_CURRENT_USER\Software\NDI\Multicast\Send)
    Sender application read from this key params to set multicast IP and mask. Then on initial client connect
    sender app sends metadata frame with next XML:
    Code:
    <ndi_multicast>
        <stream type="vmclq" address="%s" id="%s"/>
        <stream type="vmchq" address="%s" id="%s"/>
        <stream type="amc" address="%s" id="%s"/>
    </ndi_multicast>
    So, client can use multicast IP to receive data.
    Linux(MacOSX) library does not contain any symbols like I saw in windows dll. So, seems to me - not implemented yet.
