Results 1 to 12 of 12
Thread: NDI quality and artefact
    Mar 2017
    France
    10
    Angry NDI quality and artefact
    Hello,
    I have some artefact like high compression.
    All computers are i7 and test new and old ndi.
    original
    snapshot
    An idea ?
    Mar 2017
    France
    10
    Test on 2 high end pc (i7 + GTX1080 + SSD), direct LAN (no switch)
    send
    received
    It might help to send picture of what the artifacts look like and what software you are trying to use. Pictures of task manager don't tell much.
    Key Accounts Sales Engineer
    17,957
    I think these are screengrabs of the pre and post NDI video ... but I too would like to know more about the source and receiver.
    That would make a bit more sense. If that is the case, only thing that I can think of offhand is if this is OBS using the older NDI plug-in. I saw some extra compression artifacts when I tested that, but I believe the current OBS plug-in (v4.x) has fixed that problem.
    Mar 2017
    France
    10
    Yes it's pre and post NDI.
    I choose this picture because there is a lot of detail.
    More details = more compression artefact
    I use the lastest version NDI (3.1) of scan converter and monitor.
    I try an older and it's the same problem.
    What is OBS ?
    17,957
    Quote Originally Posted by rems32 View Post
    Thanks. Presumably you're running Studio Monitor? What are the source and receiver monitor resolutions, please? We will look at this here.
    Mar 2017
    France
    10
    Yes I use studio monitor in full screen.
    Both 1920x1080.
    17,957
    OK, thanks. I was able to repeat your results here, and see the same two issues - that is, some color fringing on (for example) the fine green lines of the graph, and some compression artifacts around areas of very fine detail.
    With regard to the first issue, I'm sorry to tell you this is primarily the result of the conversion to 4:2:2 color sampling for use in video. In this process, very thin (really, mostly single pixel) lines can be blended them with neighboring pixels, resulting in a color shift in places. I would predict much the same thing would occur if you were able to shoot an equally sharp image with even a very expensive video camera. Please bear in mind that NDI has been engineered for the video production realm. Very thin lines like this virtually never exist in nature, or in video. When computer graphics are supplied, thin lines are typically avoided for this and a number of other reasons.
    The compression artifacts are a different matter. In moving video, compression is extremely difficult to see ... but as you can see, they are not invisible on a freeze frame. Really, very much greater compression artifacts are often obvious even in broadcast video on close inspection. That said, we are continuing to devote a lot of engineering resources to continual advancement in this respect, and I have good reason to anticipate improvements in due course.
    Mar 2017
    France
    10
    Ok
    thank you for your response
    I must found another solution now !
    May 2007
    St. Paul, MN
    767
    I too have noticed in versions 2 and 3 that "rudimentary" feeds have these artifacts. In some of my testing I'll send some basic black text on white background and get these artifacts. I didn't think much of it because when more complex feeds are used (ie. cameras), you don't notice it.
    Zach Schuster
    SuiteCG- Sports Scoreboard and Stat Tools
    Tricaster 855/455
    Zeplay Instant Replay
    ScoreOCR
    Sony NX5U
    Mar 2017
    France
    10
    I'm happy to see I'm not the only one with this problem
