Results 1 to 2 of 2
Thread: NDI Monitor Portable
    Sep 2017
    Krakow
    2
    Hello!
    I have just started using the NDI tools.
    And actually when testing the tools both the Scan Converter and Monitor on 2 systems all worked perfectly within minutes of setting up.
    However,
    I would need to have the NDI Monitor running on a administrator locked machine which is on a domain (Lets call it Machine #2).
    Running the APP on Machine 2 is no problem. However it can not detect the NDI stream from the main pc.
    While i can access my shared folders from the main pc, I cannot see any other discovered devices in my network control panel. This seems to be the driver for the Monitor?
    I have attempted in the last hours many things to get the locked system being visible on the network but it seems hopeless, I even made a cross-cable which in the end also did not work.
    Does anyone have any idea what i could try to get access to the NDI stream on my Locked Machine?
    Hughly apreciated! and with kind regards,
    Sep 2017
    Krakow
    2
    Magically solved itself!! ?
