Results 1 to 10 of 10
Thread: FAcebook live fail tricaster 460AE
    Jun 2012
    peru
    321
    Hi i have a tricaster 460AE
    during the day did some streams, not more than 30 minutos on facebook, in some streams it end for some reasons, the counter on the tricaster stop for some reason, an the video on the facebook dissapear
    after that i update the 460 AE to the last version Version: 5-1-170720 , make one stream an work well. the second stream that make after some hours fail afer 15 minuts,
    anyone have the same problem?
    Gear Used:
    Tricaster: All 3Play:440
    Cam: JVC GY-HM600, GY-HM150U
    Facebook
    Twitter
    What do you get as a speed test on you network connection? What streaming bit rate you are trying to stream at?
    I have the same problem, I also have TriCaster 460 with advanced edition.
    I'm using the last version too: 5-1-170720
    After 30 ~ 45 minutes, the NewTek Share App disconnects while I'm streaming to Facebook with Youtube and Periscope activated.
    I stream to Facebook with 1280x720 1 Mbps. profile
    Quote Originally Posted by alejandro9999 View Post
    What does a Speediest like www.speediest.net say you get for upload speed. What is the bandwidth of each stream going out of the system? 1Mbps each?
    Question My download/upload speed
    I tried to measure a location near Facebook datacenters.
    For Youtube I send, 1920x1080 - 2Mbps
    For Periscope I send 1280x720 - 1 Mbps
    For Facebook I send 1280x720 - 1 Mbps
    Alejandro Núñez |
    Multimedia Producer and E-learning specialist |
    www.productormultimedia.com
    Equipment: :
    460 with Advanced Edition software.
    Are you using the TC460 streaming engine for everything? It can only generate a single encode that is sent to all destinations. Facebook maxes out at 720p resolution (limitation of Facebook's streaming), so it could be that it is dropping because the YouTube is trying to force 1080p encoding. Try setting everything to 720p and see if it works.
    Jun 2012
    peru
    321
    i perfom stream only to facebook 1280x720 - 768 kbps
    the speed upload is 10mb. when fail tricaster stop the stream after 10-12 minuts ,
    after i active the stream for second time it work fine the rest of the 50 minuts
    Gear Used:
    Facebook
    Twitter
    Are you using the Facebook or Custom type connection? I'm going to try with my system and see what happens.
    I just tried Facebook streaming on my TC Mini running 5-1-170720, first attempt and the stream has been going for about 90 minutes in without issue. Encoding at 1280x720@1024Kbps using the Facebook streaming preset.
    I would recommend contacting support, they will probably want a log file to see what might be going on.
    Jun 2012
    peru
    321
    i make a restore factory and update tricaster again.
    this time i manually download the intel drivers after update, because tricaster only ask me to update the nvidia drivers. for the moment work well.
    question, where tricaster have these log ?? in order to see any kind of problems?
    PD: streaming is good for now, but my animated buffer not load, only the static buffer ( test with tricaster buffers also)
    Gear Used:
    Facebook
    Twitter
