Thread: Sets from a 460 AE to a T40
    Aug 2016
    USA
    219
    So when we got our 460 AE2, we moved our VSE over to it. Today I need to revamp a set for use in our T40 v1.
    It took 5 attempts to finally figure out what needed to be done. At first to would show up with no zoom available.
    Then even though I could see the T40 over the network, it wouldn't export to it even though it appeared like it was.
    Any, what I had to do, since the VSE Advanced Edition Upgrade gives you 10 different comps windows, instead of just 2 levels of zoom.
    When making a set to put into a T40, in the second window, set your second level of zoom, and then right click and select copy and then paste it into the other 8 windows.
    Then I save and export it to the 460 and copy it over the network to the T40. That worked.
    I make things Eric Pratt's Avatar
    Orange County, Ca
    250
    It's just the last window you need to edit. On systems with only 2 zoom levels it's the first and last presets that are used.
    Eric Pratt
    Virtualset.com - Virtual Set Marketplace
    Virtualsetworks.com - Tricaster Virtual Sets
    Virtualsetworks on Facebook - Get Social
    Aug 2016
    USA
    219
    Thanks Eric.
    Also I noticed that if I make an executable and copy it over the network, it won't install, but if I put it on a thumbdrive it works as intended. Weird I thought.
