Results 1 to 9 of 9
Thread: Bridge tool similar to MODO's?
    Registered User Schwyhart's Avatar
    Mar 2013
    Tulsa OK
    279
    I have two pipes that I'd like to connect with a nice curve to it. In MODO, I can select the two end polys and do a poly bridge with settings to make it curved. In Lightwave, there are no options with the bridge tool.
    Any suggestions?
    Mar 2013
    Tulsa OK
    279
    I found this, but it won't install: http://www.artssphere.com/plugins/bezierbridge.php
    Jan 2005
    Colorado Springs
    944
    The awBezierBridge plugin installs fine for me on LW 2015.3, 64-bit on Windows 7. Works like a champ.
    mTp
    Mar 2013
    Tulsa OK
    279
    I tried the UB Mac version. When I click "Add Plug-ins" a dialogue box pops up stating that it 'Cannot load external plug-in file...'
    Jan 2005
    Colorado Springs
    944
    OK. He has a Contact page on his website, might be worth sending a message. It works really well.
    mTp
    tested it for PC some time back >
    not quite the same as Modo's i believe, but works ok.
    LW vidz   DPont donate   FogBugz   RHiggit   IKBooster   My vidz
    Mar 2013
    Tulsa OK
    279
    He said that someone else compiled the Mac version for him. This is why the Mac version is stuck at 0.9 beta, while the PC version is on 1.2.1.
    Anyone care to compile the latest version for Mac?
    7,128
    Click on Modeler's icon, and toggle 32 bit mode, and try installing plugin again..
    Jan 2011
    Seattle
    124
    If all else fails use Px_Bezier in tube mode to create a section you can weld in. It is pretty interactive, and you can control the radius of the tube and segments.
