Results 1 to 9 of 9
Thread: Rack mount UPS for Tricaster 8000
    131
    I just got a TC 8000 and I'm putting it in a road kit. I'll have a 16 channel audio board and some other same gear. I'm looking for suggestions for a rack mount UPS that would work best for the 8000. Thanks.
    Sorry for the typos, for some reason I'm getting a double image when I type this in. thanks
    4,106
    APC SMT1500RMUS should fit most racks
    After you do your power draw calculations, you might need to go with the bigger brother, APC Smart-UPS X 2000VA Rack/Tower.
    Keep in mind the big brother is a really long guy. Do your measurements based off the specs on the APC site.
    Jef Kethley
    PIZAZZ
    www.pizazz.com
    Using:
    Panasonic UB300 4k cams
    131
    Thanks I'll take a look.
    131
    There is something else about UPS that I heard that is needed to run the 8000 if the power goes out. If the UPS doesn't have it, it won't run the TC correctly due to the dual power supplies. Something that keeps the UPS from doing a perfect sine wave in the power or something along those lines. Does that make any sense? I heard this but can't remember what it's called.
    May 2004
    Vancouver, WA
    1,406
    You want a pure sine wave UPS, not a simulated or step sine wave version. The power supplies don't like that cheaper method.
    Kris
    TriCaster: 850, 850 Extreme, 855 & 8000
    CG: LiveText2 - With LT[Scoreboards]
    Cameras: Sony NX5 (SDI & ATEM with Tactical Fiber)
    131
    17,329
    There is a section on this on the manual, if that helps.
    Bloomington, IN
    1,465
    I've found a Killawatt a useful device for UPS planning. It can measure actual VA draw of stuff plugged into it. Runs $30 or so on Amazon.
    -Jeff
    My TriCaster Blog
    TriCaster Tally Lights
    Gear Used: TC1, TC 8000, TC 460, TC Mini 4i, 3Play Mini, 3Play 4800, TS 100, TS 4000
    131
    I ended up ordering the APC Smart-UPS X 2000VA Thank you for all the input.
