Results 1 to 11 of 11
Thread: Linux NDI & CentOS
    Feb 2017
    South Africa
    7
    Linux NDI & CentOS
    First up, out of interest, which Linux dist is recommended/ most stable for NDI development?
    Now my main problem, has anyone run into issues with the avahi/dbus sub sytem on CentOS 7 64? I am getting Seg faults in dbus.
    Code:
    Program received signal SIGSEGV, Segmentation fault.
    [Switching to Thread 0x7fffe4ff9700 (LWP 7871)]
    0x00007ffff679d10c in _dbus_list_unlink (list=list@entry=0x8e06c0, link=link@entry=0x7ffff0001750) at dbus-list.c:498
    498           link->prev->next = link->next;
    Generally only occurs after creating a receiver on a stream originating on a Win7 machine.
    I have installed an Ubuntu Server 16.10 instance and the code seems to be stable on it hence wondering if its a CentOS specific issue?
    Thanks, Blake
    Apr 2017
    Netherlands
    Quote Originally Posted by tbimages View Post
    I had similar issues with crashes in avahi/dbus on Ubuntu 14.04. On Ubuntu 16.04 I had no such problems.
    Feb 2017
    South Africa
    7
    Thanks for the feedback. I am experiencing similar on Ubuntu 16.10 and Debian (Jessie) as well. Mostly random from what I can see. I also find that it's more stable when running code through GDB however then it's also running ALOT slower. Makes debugging extremely difficult.
    I'm open to any suggestions for alternate ways to better debug this.
    Aug 2015
    london
    148
    if you are crashing in Avahi under Linux, see if its associated with discovery of 2 NDI sources with the same name. If so that's a known old bug, and a newer NDI Library build may fix it.
    Aug 2015
    london
    148
    We are using Ubuntu 16.10 and 16.04 and they are working well.
    Out of interest, which NDI linux library build are you using with CentOS 7 ?
    Aug 2017
    France
    6
    Hello,
    I observed the same issue with the SDK v3 on a Linux CentOS 7.3.
    Does anyone find more info on this ?
    Tx !
    Nicolas,
    Software Engineer
    Jul 2006
    San Antonio, TX
    9
    Hi all. I've been in contact with someone who managed to figure this out. It seems that the version of dbus-libs on CentOS 7.3 is a little bit buggy. This particular developer said he updated to v1.10.14 of the dbus-libs package and everything seemed to work well.
    Brian
    Aug 2017
    France
    6
    Hi Brian,
    I force-upgrade the d-bus lib and effectively, this is much more stable !
    Thanks for the feedback,
    Nicolas,
    Sep 2017
    London
    5
    Quote Originally Posted by chossette View Post
    Hi - can you give me some tips on how to do this force upgrade of dbus on Centos 7? I am having trouble finding a suitable source of packages for dbus 1.10.
    Aug 2017
    France
    6
    Hello Bob the Dino
    I do not have found an official package for CentOS with newer version. Even the next coming version 7.4 does not have update the dbus package.
    I get the package from this location:
    - http://dl.fedoraproject.org/pub/fedo...c25.x86_64.rpm
    Then force the rpm installation:
    Code:
    rpm -i --force dbus-libs-1.11.6-1.fc25.x86_64.rpm
    rpm -i --force dbus-1.11.6-1.fc25.x86_64.rpm
    Note, that you have to restart the DBUS service. This generally does not happen with great success (graphical freeze on my side). I then reboot the system with success. The system logs does not raise any issues, and I do not have observed any instability.
    Sep 2017
    London
    5
    Thanks very much - I'll certainly try that!
