Results 1 to 9 of 9
Thread: Not able to open NDI receive on Linux
    Jul 2016
    US
    I am using latest Linux SDK, ARM libraries. I am compiling NDIlib_Find example. I am able to see NDI sources, but when I try to connect to a source using NDIlib_recv_create2 function I get a return of NULL, which, as I understand, means failed connection. However there is nothing in the SDK documentation that gives any reasons why a connection would fail. There are no error codes returned by NDIlib_recv_create2. How should I go about debugging this issue? Is there some sort of a debug mode?
    Thanks.
    Aug 2015
    london
    136
    Quote Originally Posted by stefslon View Post
    Thanks.
    The ARM library doesn't support receiving NDI at present.
    Jul 2016
    US
    Thanks, livepad. Was it in any of the documentation and I just missed it? Alos, any idea when or if there will be a support for ARM?
    Dec 2016
    Seal Beach, CA
    Darn, just ran into this too. Wish it was at least documented somewhere.
    San Antonio
    754
    This is going to be added in the near future. We do not currently have a fully optimized ARM path through the codec (which is a lot of work).
    Nov 2017
    Stockholm, Sweden
    5
    Any news on this topic? I just tried this and it still returns NULL.
    San Antonio
    754
    Quote Originally Posted by GuFe View Post
    I am afraid that there still is no optimized ARM codec that we consider fast enough for production use. In the previous newsletter however we did ask that if anyone has an interesting interest in helping us produce this codec and knows ARM assembly that we would be happy to make an open project to develop this. Just email ndi@newtek.com. Ndi receiving is fully supported on all intel platforms, including Linux.
    Nov 2017
    switzerland
    Quote Originally Posted by ACross View Post
    So there is the possibility that you can provide us a kind of alpha-arm-version which is not as fast as expected for production use but already runs on arm devices?
    Unfortunately my arm coding skills are not high enough to help in codec development, but would still love to test the NDI functionality, even if it is slow for the moment.
    Jan 2018
    Wisconsin
    Quote Originally Posted by magdesign View Post
    I would also be interested in an alpha version if it were available.
