Results 16 to 30 of 30
Thread: driving morphs based on null direction
    skeptic lertola2's Avatar
    Dec 2008
    New York City
    1,039
    marchermitte I did not really understand what your node setup was doing. Attached is a scene that may be along the lines of what you want. It has tentacles that reach towards a null. As the null moves the following tentacles lag behind using the Follower motion modifier. This scene uses scaling to get the tentacles to reach towards the null instead of morphs.
    scale_to_null_with_weight_map.zip
    Thank you Lertola.
    The use of a double null with follower is pretty smart. While this is not what I had in mind (getting the info of the null motion to fire the corresponding morph, ex: morph map "tentacles.bend_Left" when the morph goes to the left, "tentacles.bend_Right" when It goes to the right, etc.). It could work for what I had in mind. I did get more or less the result that I was looking for with polychains and dynamics but It's more like a challenge now to get that direction info translated into nodes.
    Your node setup is impressive for me as I'm not a serious node user.
    Thank you for your time and for the scene that I'm studying more carefully now.
    This is the dynamic version btw...Click image for larger version.
    da what? daforum's Avatar
    May 2006
    Bristol, England
    1,599
    marchermitte, that looks great!
    Any chance to see how you did this?
    Mar 2006
    in lights
    2,101
    yes .. great effect!
    Yes, no prob, I will post a scene or a fast video...
    Dec 2008
    New York City
    1,039
    looks cool
    Pessac
    4,774
    I'm in a situation where I need a tyre shape to inflate in areas until it is completely inflated. I thought about driving a morph with a null, but I guess I need a second null to inflate only the portions I want to "blow up"? In effect, this isn't for a tyre really, I want to simulate a weld being made, it's just in a ring.
    Thanks for any ideas.
    B
    LightWave 3D Trial Edition
    AMD FX8350 4.2 GHz, Windows 7 SP1 Home Premium 64-bit, 16GB RAM, nVidia GeForce GTX 960 (388.59, 4GB and 1024 CUDA cores)
    Laptop with Intel i7, nVidia Quadro 2000Mw/ 2GB (306.97 and 192 CUDA cores), Windows 7 Professional SP1 64-bit, 8GB RAM
  9. #24
    Vacant, pretty vacant pinkmouse's Avatar
    South Yorkshire
    1,668
    So you want to grow a welding bead in a circle?
    Al
    "I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while." Charles Fort
    My Website
    My Lightwave Tutorials
  10. #25
    Pessac
    4,774
    That's exactly it.
    B
  11. #26
    South Yorkshire
    1,668
    Hmm. My first thought is not to use a morph, but to make a section of weld fillet, (to whatever size /scale is appropriate for your animation), clone it into a suitable size circular array, then use DP kit Part Move to move them in turn from a hidden position under cover of the welding arc.
    Al
    My Website
  12. #27
    Pessac
    4,774
    Funnily enough, that's what I did, but with instancing and the client doesn't like that he can see the lines of the separated parts. So I wanted to use the morph idea to make the geometry intact so that smoothing would work across it. I just wanted to have a more organic look to it, but even if the morph could proceed around the circle, rather than being all at once, that would be good.
    B
  13. #28
    Dec 2008
    New York City
    1,039
    B
    Here is an example a morph being animated with nulls. Maybe something like this could work:
    http://forums.newtek.com/showthread....=1#post1420701
  14. #29
    May 2006
    Bristol, England
    1,599
    You could use a morph along bones and add textured displacement to the bones ( or just a few )
    and as the morph grows it bumps ( and lumps ) as the circle is created.
    Hope it helps
  15. #30
    pretty much this >
    https://www.youtube.com/watch?v=JZJcvrJd7qM
