Results 1 to 1 of 1
Thread: Using Larger drives on a 3Play
    PROBLEM DESCRIPTION
    The use of higher capacity drives with 3Play has been tested as follows:
    Machine: 3Play
    Drive used:
    Seagate Barracuda 7200.14 ST3000DM001 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s
    The drive performed well and so long as basic specs are not lesser it stands to reason that drives larger than the one tested should also work.
    It should also be noted that in regards to video drives, “green” drives should be avoided since their power saving features may cause performance issues.
