Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: New look and functions to Modeler's Transform gizmo
    So many don't know that modeler has a new tool since 11.5 called Transform. It is the Move, Rotate, Scale, Scale Axis wrapped all into one viewport gizmo handle. Allowing you to define any point, polygon, edge or center as a defined plane for it's functions. (page 1347 in the Lightwave2015.pdf) From those that have used it say it gets unusable at small sizes since it inherits the size of the item in selected for it's functions. I have created a new version that makes more sense on how the tool functions and also should work better at smaller size edits. Here is the list of changes to the Gizmo.
    Axis Lines:
    1) Lengthened the size of the axis lines.
    2) Increase the size of the end cone.
    3) Added a smaller end cone to the other side of the axis lines. (smaller represents negative)
    Rotation Arcs:
    1) Added another arc handle 180 from the original.
    2) Added colored elipses to connect the arcs. (also selectable and highlights)
    3) Color coated the arcs to the relative axis they rotate around. (original is not this way which is confusing)
    Scale Axis Boxes:
    1) Sized up and moved the axis scale boxes.
    Plane Axis:
    1) Moved them to the outside of the gizmo center.
    2) Changed them to squares to represent a plane.
    3) Added colored lines to show which two axis it will move along. (also selectable and highlights)
    Scale All Box:
    1) Increase the size.
    Now to use this new look, make a backup of the one that shipped with Lightwave incase you don't like the new look. It should be located in <Lightwave Dir>\support\gizmos\transform.lwo. Just replace the object and you are good to go. Enjoy and let me know what you think.
    -M
    Attached Files Attached Files
    I was thinking of the immortal words of Socrates - "I Drank What??"
    How very cool, yes I really like this tool. In fact I have it mapped to my "t" for move shortcut (ala Larry [RIP])
    Yes i also don't like native one (too small/crowded) particularly so i have my, great thing is that it's user changeable so kudos for DEVs to make it that way.
    Thanks for sharing your version.
    Here is my.
    RAM-Studio
    Singapore
    220
    This amazing MSherak! Sorry, a little sidetracked, do you know how to increase the font size of the UI. I really got hard time reading them.
    Super Member jboudreau's Avatar
    May 2003
    Halifax
    924
    Quote Originally Posted by MSherak View Post
    Axis Lines:
    Rotation Arcs:
    Scale Axis Boxes:
    Plane Axis:
    Scale All Box:
    -M
    Thanks man, I also posted about this a few days ago. It's awesome that lightwave allows you to model your own custom gizmo. Here's the link to my gizmo if you haven't seen it.
    http://forums.newtek.com/showthread....zmo-in-Modeler
    Jason
    VFX Artist / 3D Animator
    Animatrix Productions
    Dell T7600 Dual XEON E5-2687W 3.8GHz / Dell M6700 i7 -3940XM 3.9GHz
    64GB Ram / 32GB Ram
    Nvidia Quadro K5000 / Nvidia Quadro K5000M
    Windows 7 x64
    It's nice but color not tell me which axis it is (x,y,z) and i don't know i which way values growing or decreasing, arrows are on both sides.
    Vacant, pretty vacant pinkmouse's Avatar
    South Yorkshire
    1,671
    One thing that really annoyed me, and meant I gave up with the original Transform tool, was that if you hit A, (or Shift A), to fit the selected object onscreen whilst using it, it defaulted to the plane/edge/point you were using as a guide, not the actual object you wanted to manipulate.
    Does it do the same in 2015?
    Al
    "I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while." Charles Fort
    My Website
    My Lightwave Tutorials
    Time Traveller Andy Webb's Avatar
    Hertfordshire UK
    2,048
    Hi MSherak, that's just great, I gave up on the transform tool, just didn't like the way it worked but this works great
    Andy Webb
    Intel core i7-3820 3.60GHz
    Asus P9X79 Deluxe motherboard
    GeForce GTX 660
    16 Gb RAM
    Windows 10
    Quote Originally Posted by pinkmouse View Post
    I've reported that problem back then and it's fixed in 2015 . Zoom to selected just wasn't working into sysncmesh system before (11.5/11.6), now it works fine in 2015.
    RAM-Studio
    Hertfordshire UK
    2,048
    Unfortunately if you are working on a really small object the gizmo stops working.
    Fortunately for me I rarely work that small.
    Andy Webb
    GeForce GTX 660
    16 Gb RAM
    Windows 10
    South Yorkshire
    1,671
    Quote Originally Posted by Lewis View Post
    That's good to know. Ta
    Al
    My Website
    May 2003
    Halifax
    924
    Quote Originally Posted by Andy Webb View Post
    Does it stop working on a small object in version 2015?
    I know the gizmo I modeled had no problems with objects small. I'm pretty sure It would work on an object as small as 200um. I'll double check and let you guys know
    Thanks,
    Jason
    64GB Ram / 32GB Ram
    Windows 7 x64
    Quote Originally Posted by battery555 View Post
    To change the whole UI font for Layout or Modeler you have to add to the command line on the launch icon. Add -f"<name of font>@<font size you want>" so for example, -f"Tahoma@12"
    Quote Originally Posted by MarcusM View Post
    Can easily be added.. Remember that the inputs when using this tool become relative to the handle.
    welcome
    Quote Originally Posted by jboudreau View Post
    Thanks,
    Jason
    2015 this works at .0002 just fine.
    -M
    Axes grinder- Dongle #99
    Seattle
    14,225
    @^@ The convention is RGB=XYZ/HPB/XSYSZS.
    But you did get that you can make your own, did you not? Add labels to your heart's content. Go crazy.
    I'm really psyched that the size issue has been fixed -- obviously this is a lot more useful.
    #aflw -I dis-recall: are there Falloff options for Transform?
    Praise to Buddha! #resist
    ok for some reason can't update the 1st posting I did so here it is..
    Updated.
    1) Changed the axis so the large cones point down the positive inputs for the tool. (Z flipped from original one)
    2) Moved the Plane handles to the axis which makes it cleaner.
    3) Labeled the axis with XYZ which they are on the positive input side.
    Enjoy,
    -M
