Results 1 to 13 of 13
Thread: Blender Fluid - Obj Sequence
    Jan 2004
    Broken Arrow, Oklahoma
    918
    Looking for a good way to work with the blender obj sequences that the fluid sim puts out. In particular a way to adjust the surface of the entire sequence of obj's, or save them as lwo's. There are some hit and miss things on older versions of LW and Blender around, but haven't seen anything recently.
    Someone have a work flow or seen something?
    Nov 2006
    Burbank, California USA
    4,576
    You could load up all your objects into Modeler or Layout, then in Surface Editor set the mode to Scene. Then you can edit all the surfaces as one (assuming the surface name is the same).
    There's also this.
    https://www.lightwave3d.com/assets/p...ntry/surf-rep/
    There might be other options too as this is a common topic for people working with RF or obj sequences from another package.
    Profile piece
    2010 Reel
    'The X's' Reel
    Jan 2004
    918
    Quote Originally Posted by nickdigital View Post
    There's also this.
    I think the surf-rep might just work. Thanks Nick!
    Jan 2004
    918
    hmm...ok the surf-rep plugin/exe only wants a LWO sequence as it's just for RealFlow. Any chance you know of an easy way to convert 203 OBJ's to LWO's?
    Nov 2006
    4,576
    You could load them all into Modeler or Layout. Not sure of an easy batch process without making one via lscript.
    Profile piece
    2010 Reel
    'The X's' Reel
    Flipbook Productions Rollie Hudson's Avatar
    Washington DC
    80
    I've struggled with this too - never getting completely past the sequence - unsurfaced running in Lightwave. However, I suspect the trick (or one path) is to get the surface working in Blender (which I have not yet mastered myself yet) and then get Lightwave to correctly read that material surface info in the .obj sequence once you bring it into layout and activate the import sequence/object replacement function which makes the fluid appear to flow in Lightwave Layout.
    Mac OS X
    MacPro Workstations
    it's a manhole cover ↓ JoePoe's Avatar
    Jun 2006
    LISA
    1,968
    Quote Originally Posted by tcoursey View Post
    Open your .OBJ sequence in Layout using standard the Object Sequencer, then save out the sequence as .LWOs using IL Save Transformed Object Sequence ls script.
    (bunch of other cool batch process plugs there too )
    System Specs: A pile of sand, a couple of wires, a real live mouse and a beer.
    Banned OnlineRender's Avatar
    Dec 2008
    Glasgow , Scotland , UK
    6,260
    JoePoe is pretty spot on , or you could use splotchdog plugin kinda does that for you .
    Jan 2004
    918
    Quote Originally Posted by JoePoe View Post
    Perfect, I'll give that a go. I ended up just doing it manually on this quick piece I only had 90 frames of animation. So it wasn't terrible. But if I was to begin using this workflow more I would NEED a batch process. Sounds like this may be the trick. Thanks everyone.
    I always wanted to try this but I had no idea where to start.
    Here a Layouter script we wrote for just such a case. You can copy your surface to a hole object sequence without opening all the files...
    mc_mod_copysurfs.zip
    Roman
    Jan 2004
    918
    Quote Originally Posted by RomanS View Post
    Roman
    Thanks Roman, I know it can be used by many. This topic comes up a couple times a year!
    Red face
    Here´s the project behind the script. We rendered it in Lightwave but there was no way to animate it there
    So we exported the animation as object sequence from another application. Is was the only way to chance surfaces efficently because the sequences were long and heavy (about 250 MB per object)...
    https://vimeo.com/64726323
    Roman
