Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 56
Thread: Speed Modeling Challenge #228 - Pixar
  1. #16
    South Yorkshire, England
    2,497
    Lol. One of your favourite characters too! Nemo was the first film I took my eldest boy to see at the cinema, it is one of our favourites and he will still sit down and watch it with me (he's nearly 11, lol).
    For me, this time, the mesh was so frustrating... I don't know if it was because I was trying to fit it in between client work, I was tired, not paying attention or what, but I could not get the polys to work for me. Ended up being 3hrs of modelling, which I am not happy about as that is not a difficult character. I need to learn to stop zooming in and out all the time and just get on with a base mesh and look at the detail later. All started from octagon.
    Steve, what did you do to avoid 5 point pinching around the edge loop for the fins?
    Oh well, on with the next one.
    Here's some nice hi res reference images if you need them for texturing -
    http://www.pixarblog.de/wp-content/u..._3d_bruce1.jpg
    http://www.pixarblog.de/wp-content/u..._3d_sharks.jpg
    And some wires (animated gif) and a render -
ID:	116264Click image for larger version.
  2. #17
    Quote Originally Posted by Waves of light View Post
    Usually what I will do is create a secondary loop before the mesh changes trajectory so that its on a flatter surface to avoid pinching. So basically I make sure my polygons 'surround' the area I want the fins to be extruded from. Then I create a loop within that area, then pull another loop out still on the flat surface, THEN I start to extrude the fins. Just try to keep your stars on the flattest area as possible without a lot of curvature or direction change.
    I started Bruce with the mouth to make sure to put the good poly flow around the mouth so I could get the smile lines in. Then it was just a matter of creating a loop for the eye, creating the ridge above the eyes then patching in between. Then it was just a matter of extruding my edges backwards to the tail. Went pretty quick actually. The worst part for me was the mouth. I made a mess and probably spent 20 minutes cleaning the inside of the mouth the way I wanted it (and its still not there but good enough). I modeled a single tooth and then just copied and pasted it around one side of the mouth then mirrored that over to the other side.
    I also ran into a bit of timesuck while I made the conversion to higher density near the face to lower density at the tail. Normally, not a problem but I didn't really consider it ahead of time since it was a speed job. Thanks for the images, that second one I actually used for a side profile while modeling.
  3. #18
    2,497
    I should have started with the mouth, but I was sort of directed by one of the images I linked to in the previous post, which is a side view shot from Pixar. So I thought more about length and fin placement, by which point I got to the mouth and the trouble started. I was going to use PlaceMesh for the teeth and then attempt to model the eye socket, but I gave up after I saw the timer! I will keep it, as I can always stick it into 3DCoat as a base mesh and voxel sculpt and texture a better version.
    Thanks for the tips on the pinching. Are you going to texture him?
  4. #19
    Not sure, I might try to paint him up in Zbrush, its just a matter of if I will have time. BTW, I added more to my previous post.
  5. #20
    Jun 2013
    Pandora
    74
    Already some really good stuff findig nemo seems to dominate. I wanted to try nemo maybe
  6. #21
    Aug 2010
    Kernow
    1,969
    Buttercup.
  7. #22
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    999
    Coming in @ 120 minutes... EVE!
    Nothing fancy here... mostly slice, saw, multishift and extrude... and some help from LWCAD's line tool (for fancy, precise slicing...)
  8. #23
  9. #24
    2,497
    Great entries. Can't wait to see what you come up with Kuzey - timelapse again?
  10. #25
    Nov 2010
    Albury
    102
    Don't forget about the mascot!
    Modelling about 30-40 mins, texturing and lights bout another 30-40.
  11. #26
    Pixel Monkey Pantagrool's Avatar
    May 2006
    Boston, MA
    46
    For Pinkmouse:
    One quick thing I noticed is that you modeled the bow-tie as part of the main mesh. At this stage in your modeling career, I'd suggest you have that as a separate mesh. (That would also extend to his beak, feet, and [future] eyes.) That way you don't have to wrestle with control loops and wonky polygonal flow -- especially during a time-limited challenge!
  12. #27
    Vacant, pretty vacant pinkmouse's Avatar
    South Yorkshire
    1,669
    Now where's the fun in that! ?
    I think it's a mindset problem. I've got a good grip on hard surface modelling, though perhaps I'm a little slower than an expert, but those techniques don't seem to help much with soft body work. I suspect I need to start again from scratch, and ignore everything I've learnt. Then once I've got the hang of soft body, I can go back and combine the two systems into a fully rounded technique. I'll probably hit Youtube this morning for some tutorial stuff, then have another go later today.
    Al
    "I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while." Charles Fort
    My Website
    My Lightwave Tutorials
  13. #28
    Registered User Kuzey's Avatar
    Melbourne
    5,262
    I'm so hoping this challenge gets a one week extension
    I backed up my HD without saving my LW menu setup & now all that work is gone...grrr
  14. #29
    Jun 2013
    Pandora
    74
    Can the contest also last longer then 1 week? Didn't know about that. If you want I can also extend it to 2 weeks
  15. #30
    Melbourne
    5,262
    If more people want an extension then it might be a good idea...otherwise..I'll see if I can take part in the next one
