Thread: LW 11.6 Python PRIS module
    Banned
    Apr 2005
    Valencia
    3,145
    I just spotted this on the documentation of LW 11.6, but page 316 doesn't say anything about what it is.
    Can someone of the developers give a short description of what it is?
    Thanks,
    David
    Super Member LW_Will's Avatar
    Somewhere, Out there...
    1,188
    Motoslave?
    Will Silver
    Animator
    digital TRiP
    "Frak'em all! I USE LIGHTWAVE!"
    Sep 2006
    Future Past Life
    1,874
    I've only had a brief glance at it, but at first glance PRIS seems to be an invisible layer of doom of Python for LightWave. It seems to be a replacement of the pcore module moving forward. You can no longer get help on pcore nor can you get help on pris or even lwsdk.pris. It's so invisible that you can only call it, but not knowing what methods it contains is problematic. The bright side is the code is needed is a LOT cleaner.
    PRIS is short for PRIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIS!
    Banned
    Apr 2005
    Valencia
    3,145
    [QUOTE=BigHache;1336319You can no longer get help on pcore nor can you get help on pris or even lwsdk.pris. It's so invisible that you can only call it, but not knowing what methods it contains is problematic. [/QUOTE]
    Aggh! That is no good then, I'm having similar problems getting help on "other" python SDK, and I managed to get it using the inspect module. I was very glad that the help() command was so useful inside LW!
    Cheers,
    David
    Sep 2006
    Future Past Life
    1,874
    This is pre-release too, so that's not to say this is final behavior. I've filed a bug report (63961) just in case as it doesn't seem correct, especially since help('pcore') isn't functioning.
    Sep 2006
    Future Past Life
    1,874
    Well help('pcore') is back with a vengeance and has grown to 23k+ lines. Yay!
    I missed this because for whatever reason I have not installed 2708 at home yet (keep forgetting). Within the SDK folder there is a zip file called "lwpython11.6". These docs are growing to be a very nice place of information, and they include information on PRIS (which turns out is NOT short for PRIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIS).
    So a big shout out to the O to the P:
    (from the lwpython11.6 docs)
    Python Reduced Instruction Set
    LightWave 11.6 introduced a new set of Python modules called the Python Reduced Instruction Set, collectively known as PRIS.
    PRIS seeks to reduce the complexity of LightWave Python’s direct exposure to the LightWave SDK by providing a collection of functions that encapsulate that complexity for many of the more common actions your plug-in may perform. In addition, this simplication layer has been implemented entirely in Python, a format that affords modification, or extension via additions, on your part should you so choose.
    Each PRIS module can be accessed in Python through the existing ‘lwsdk’ module. If you wish to examine or modify any PRIS module, you can find them under the ‘bin/lwsdk/’ package directory of your LightWave 11.6+ installation.
    So basically it's trying to get the Python implementation to look and feel more like LScript. This was laid out on the roadmap but it's just cool that we're getting there now.
    Banned
    Apr 2005
    Valencia
    3,145
    Thanks for that finding.
    I dont have the latests build installed waiting for the next one to fix Spline Control.
    Looks like that with the PRIS module maybe it will be easy to prototype plugins in Python now.
    Cheers,
    David
