Results 1 to 8 of 8
Thread: lightwave 11.5 merge triangles?
    Newbie Member alkart2003's Avatar
    Sep 2005
    Kingsport,TN
    74
    Can somebody tell me whwere the merge triangles option is? I seen it in an advetisement in the lightwave newsletter fall 2012 issue. Did they add this or not?
    Nov 2006
    Burbank, California USA
    4,576
    Not sure about the native one.
    I use this one.
    http://www.lwplugindb.com/plugin/mergetrigonsx/
    Profile piece
    2010 Reel
    'The X's' Reel
    in LW11.6 it's under Construct / Reduce / Merge Triangles
    i'm not sure that it made it into 11.5...
    LW11.6's Merge Triangles is faster than the other one
    Nice!
    that's very good when importing meshes with tons of trigons.
    Professional amateur Amurrell's Avatar
    Dec 2005
    Lincoln, NE
    1,350
    They seem to work about the same speed for me, and when using either one of them they have a problem working across 2 or more layers. LW version will work across 2 or more layers as long as there is a selection made, but if not, you will merge the triangles on the first active layer and destroy the meshes on the others. MergeTrigons X is good, but again does not work across multiple layers, which I wish it did recently, while I was reducing polygons on that Hubble telescope file from NASA. Got it done and reduced 1.5mil to just over 500k using remodeling, combining polys and using the MergeTrigonsX plugin.
    --Andrew
    Bono Animo Esto
    Intel Core i5 3570k
    nVidia GTX 970
    8GB DDR3 1333MHz
    Windows 10 Pro 64bit
    Maybe it's a Mac thing then cuz M TrigonX is very slow with large selections with the progress bar popping up as soon as you do more than fifty tri's at a time where as the lightwave one is instantaneous even with multiple thousands of tri's selected and yes I'm using both in LW11.6 in 64bit mode
    Pessac
    4,848
    I think that's because MergeTrigonsX for Mac is just an LScript, not a compiled plugin.
    B
    LightWave 3D Trial Edition
    AMD FX8350 4.2 GHz, Windows 7 SP1 Home Premium 64-bit, 16GB RAM, nVidia GeForce GTX 960 (388.59, 4GB and 1024 CUDA cores)
    Laptop with Intel i7, nVidia Quadro 2000Mw/ 2GB (306.97 and 192 CUDA cores), Windows 7 Professional SP1 64-bit, 8GB RAM
