Results 1 to 15 of 25
Thread: Grit Node for 11.5?
    Dec 2007
    Irving, Tx.
    550
    Grit Node for 11.5?
    Does anyone know if Grit Node is available for or compatible with 11.5?
    Mac Pro Dual Quad Core, 6 GB RAM, NVIDIA QuadroFX 2000 2GB Ram, 2 TB HardDrive LW 2015
    I Wished My Brain Came With A Manual... I could look up everything I've learned sorted by topic...
    I've been using it in 11.5 with no problems.
    Sep 2005
    Earth
    3,121
    Yup works perfectly!
    Mar 2011
    Wisconsin
    222
    where does one get this grit node?
    Super Member Snosrap's Avatar
    Aug 2004
    Ohio, USA
    4,800
    I've given up on EE grit node. I wish NT would write a similar more robust node. On large meshes it works pretty good, but on smaller ones it starts generating artifacts - especially with SubD objects. I've reverted to weight maps and the many available occlusion shaders to get my dirt in the cracks - a little more work, but far more control. I've also used modo's great occlusion shaders and baked out a UV map and applied it my objects to get a great "dirt in crevice" or "shiny high areas" look. See example attached.
    Registered User speismonqui's Avatar
    Jan 2008
    Panama
    504
    Quote Originally Posted by torturebori007 View Post
    http://www.lwplugindb.com/plugin/grit-node/
    direct:
    http://katastro.fi/~eetu/gritnode/
    Dell XPS8700 Quad Core i7 4790@3.6 - 16 GB DDR3 - GeForce GTX 750ti - Windows 10
    Dec 2007
    Irving, Tx.
    550
    Are any of you using the Mac version of LW by any chance?
    Sep 2005
    Earth
    3,121
    I used it recently to make this car a bit rusty. After texturing the model which took not more than 5 minutes I created a uv map with the new UV unwrap tool in modeler. Finally I baked the texture to the uv map. To make it ready for export to what ever app.
    Dec 2007
    Irving, Tx.
    550
    That's a very nice render! I'm having trouble with Light Wave not accepting the UB version of the plugin. I keep getting an error message. I've used this plugin in LW 11 but now it's not accepted by the software. At least that's what it looks like. I put the plugin in the 11.5 plugins folder and launched Modeler. From there I went to Utilities/ Add Plugins, chose Grit Node UB and then the message "Cannot Load External Plug-In File..." comes up. Any thoughts?
    Richard
    Richard
    Sep 2005
    Earth
    3,121
    Thanks! Could it be a 32bit 64bit problem?
    Stuttgart, Germany
    13,446
    Quote Originally Posted by Richard Hebert View Post
    I just checked the compile from 20.07.2011 - copied it to ~/Library/Application Support/NewTek/LightWave/11.5/plugins, started Layout and there it was.
    However, it seems that the one on the site is older and probably not 64-bit then. I've attached the current build (I hope Eetu doesn't mind).
    Cheers,
    Mike
    Attached Files Attached Files
    Dec 2007
    Irving, Tx.
    550
    Thanks guys, that was the problem. I would have never discovered that one. It's almost like 32 bit never existed. I have to remind myself of this next time around.
    Mar 2011
    Wisconsin
    222
    Gracias amigo!
    Polygon Whisperer
    helsinki, finland
    8
    Hi fellas, long time no see
    I added lightwolf's build from this thread, as well as Phil's from ee_gritnode - Mac32 and Mac64, to the plugin homepage, maybe that will help with any future confusion for Mac guys.
    Holy damn, I just realised this plugin is 15 years old!
    eetu.
    Dec 2007
    Irving, Tx.
    550
    It's an oldie but surely a goodie!
