Results 1 to 15 of 23
Thread: Bullet tests - share your results
    Carbon fibre dongleŽ 50one's Avatar
    Jan 2011
    Azerbaijan
    2,220
    Does anyone got some cool Bullet test and willing to share?
    I'll start - all settings default, any idea why so many cubes are getting throught the mesh? is it because it's one sided poly and gravity should be lowered?
    Why on earth the embedding videos doesn't work here?
    Los Angeles
    6,700
    Quote Originally Posted by 50one View Post
    Here are some recent 11.5 Bullet tests I recorded:
    http://www.youtube.com/watch?v=oCkuyIYHXuA
    http://www.youtube.com/watch?v=H-kQRSsaCpg
    I've got a bunch of others. Will post them when I have time.
    You mean like this?
    When in Advanced Edit mode, just click the embed video button (filmstrip icon) and paste in the URL to your page (actual page URL, not the embed code.) I know this works with YouTube but I haven't tried it with Vimeo yet.
    G.
    Los Angeles
    6,700
    Just tried the embed video button with a Vimeo page and it works fine too.
    Jan 2011
    Azerbaijan
    2,220
    Thanks, I missed it somehow. But it won't work on the mobile devices anyway for some reason( only youtube vids are visible)
    That carpet looks sexy BTW.
    Los Angeles
    6,700
    I'm not 100% certain but I think there's a special format or option in the Vimeo controls for mobile devices like iPhone. I haven't used it but I thought I read about it. If not, never mind.
    G.
    - - - Updated - - -
    Doesn't it though? I just want to roll around naked in it.
    Um...maybe that was too much information.
    Why do the little cubes fall through the container? What if you subdiv the container several times?
    I recall reading in the manual that for best results the collision object should have some thickness/volume. That might be the problem here.
    Los Angeles
    6,700
    Quote Originally Posted by art View Post
    Yes, this is correct. In our current short film project, we have many hundreds of leaves blowing around and rolling across the the ground and we ran into this issue in early tests. Giving the ground object some volume beneath the surface solved this problem. Note: you only need to thicken 'flat' collision objects for the 'calc' scene. If you bake the results (which you should do anyway for network rendering,) you can bring the items into the 'final' scene that doesn't have all that extra 'thickening' geometry.
    Super Member COBRASoft's Avatar
    Dec 2005
    Oudenburg, BEL
    3,142
    Ball Machine 01
    I've made a simple anim with Bullet and the new Node Edges. Had quite some fun while doing so . LW 11.5 rocks!
    Jan 2011
    Azerbaijan
    2,220
    Nice test CobraSoft!
    BTW.
    Added volume to my static object and also tripled the whole scene just to be sure...and still most of the small cubes are getting through?
    All settings default - cubes are 10mm^3.
    Pessac
    4,688
    What collision margin are you applying?
    B
    LightWave 3D Trial Edition
    AMD FX8350 4.2 GHz, Windows 7 SP1 Home Premium 64-bit, 16GB RAM, nVidia GeForce GTX 960 (358.91, 4GB and 1024 CUDA cores)
    Laptop with Intel i7, nVidia Quadro 2000Mw/ 2GB (306.97 and 192 CUDA cores), Windows 7 Professional SP1 64-bit, 8GB RAM
    Jan 2011
    Azerbaijan
    2,220
    B
    5mm, but at the moment lowered it to 3mm for the cubes and doing the sim as we speak - 50% done.
    Edit:
    HAH, once I've increased the size [500%] the sim time is now around 1min - nice drop from 32 minutes...
    Anyway, done a couple of test with the bigger mesh, increased the margin collision[anything from 1 - 25mm], done tests with the use glue, breaking angle unchecked and the results are always the same, most of the cubes getting through domain after initial impact. experimented also with 'merge points' mass / density, 'parts' and convex pieces, nothing seems to help...
    OK, some more observations - increasing the cubes size to[as manual suggested >0.4 m object] 0.6m^3 seams to solve the issue with tunneling, once I'll get time to do a video, I'll post it here.
    Here's is the result for the cubes being 60mm^3 and collision margin set to 10mm on both domain and parts object.
    Here's the tunneling test for the .6m size cubes:
    Would be great to have the same performance level as in XSI Ice / Lagoa , will try to do more advanced tests since I've tested the settings now.
    https://www.dropbox.com/s/g9ex24ujiz...blocks_rgb.flv
    Los Angeles
    6,700
    Quote Originally Posted by COBRASoft View Post
    That is fun! Thanks for sharing.
    G.
    Los Angeles
    6,700
    BTW.
    You might try subdividing the big box too. I think large polygonal surfaces may reduce precision--better to give Bullet smaller polys to work with.
    G.
    Jan 2011
    Azerbaijan
    2,220
    Quote Originally Posted by Greenlaw View Post
    G.
    Yeah, worth trying to subdivide the mesh instead of scaling up, gonna test it tommorow.
    Anyway, does anyone knows if the object mode is changed to parts" hpw the mass is calculated ? Total mass/ number of parts? I tried changing it to anything between 1 -10000 kg and it seems to have little effect.
    So far I'm really impressed with the calculation time! Around 1minute for 120 frames with those 10k cubes(.6m^3).
