www.lemonade3d.com
looks nice, but maybe it looks a bit more like wax than foam?
how about trying hypervoxels or instancing instead? could be better.
Damn that's pretty good so far! Not too sure what to recommend to make it better though.. maybe a lower Fresnel on the reflection so it's a bit less shiny?
pass:sword
"shifting of colors in reflection" - try to use refraction dispersion (Dielectric mat. or Refraction Shader).
Motion Design Lead
Agreed with Tobian, good progress so far! To add specular colouration, I think the easiest solution is to feed a Turbulence texture into a Gradient input, then simply add the desired colours as keys. Pipe the gradient output (which should look like a wild collection of rainbow colours by now) into the colour input of your specular shader of choice, and viola = instant rainbow highlights. Using your existing normals or the DPkit Bump to Normal node to influence individual shaders (such as a secondary gradient node with input set to incidence), you can get a lot fancier, but this is usually where I start.
Motion Design Lead
Learning
Motion Design Lead
Thanks! It was a fun little test to work on.
I posted a render to YouTube with a few more details on how the shader was developed, along with a quick image sequence of tests showing the development progress and a turntable of the results.
http://www.youtube.com/watch?v=QxO9yYgg3Wk
That was an excellent explanation on YouTube, and let me know I'll never be a master of surfacing.
But many thanks for the lesson!!!
looks superb! :]
how would it look with displacement on the big bubbles though?
i think it should work fine and look good (?)
Motion Design Lead
Glad you like it! Bubble displacement certainly looks better in some ways, less so in others - because I'm using inverted normals to shade the back of each bubble, displacing the larger bubbles means the back reflections get...weird.
I'll post an example once I get a chance to render one out (currently waiting on some heavy duty video encoding on a different project).
www.lemonade3d.com
Tnx for the replys guys, and for your inputs!
Tobian- tnx, ill try that!
Off- i will give your idea a go as well, tnx!
Iaian7- tnx a lot for taking time on this one! I love your shader, but i would like to keep the displacement!
i'll try your idea with the rainbow gradient! Btw, any chance i could get that surface of yours?
Tnx again!
I definitely think with only minimal expansion that would be a great article for 3D World or LightWIKI. Just expand a bit on each sentence for knuckleheads like me (e.g.: must there be actual Thickness for the Thickness node to operate???) and WALLAGH! Article.
Valiant NewTeKnight
UI Designer @ NewTek
How Old? Really? Aww Heck
Iaian7, very impressive! Would look forward to the tutorial & node setup as mentioned on youtube.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
