Page 1 of 3 123 LastLast
Results 1 to 15 of 42
Thread: instant teapot
    Mar 2012
    Auckland
    4
    instant teapot
    Is there an instant teapot model. Can't find it in the create menu or add it from "edit menu" .
    Pessac
    4,813
    It depends what version of LightWave you are using. The Utah teapot was a preset for a long time, but has been removed from Modeler since v9, I think.
    B
    LightWave 3D Trial Edition
    AMD FX8350 4.2 GHz, Windows 7 SP1 Home Premium 64-bit, 16GB RAM, nVidia GeForce GTX 960 (388.59, 4GB and 1024 CUDA cores)
    Laptop with Intel i7, nVidia Quadro 2000Mw/ 2GB (306.97 and 192 CUDA cores), Windows 7 Professional SP1 64-bit, 8GB RAM
    Mar 2012
    Auckland
    4
    Thanks, glad to know I hadn't imagined it.
    Oct 2003
    Near Edinburgh
    246
    Teapot files
    Hi, 32 and 64 bit versions of the Utah teapot. Works with 9.6, haven't tried with any other version.
    Regards
    Iain.
    Attached Files Attached Files
    Pessac
    4,813
    I can confirm it works in the very latest LightWave too.
    B
    Mar 2012
    Auckland
    4
    Thanks Iain it's working
    da what? daforum's Avatar
    May 2006
    Bristol, England
    1,606
    Quote Originally Posted by iain_r View Post
    Regards
    Iain.
    Is there a version available for Mac (either as a .plugin, or .ls)??
    Oct 2003
    Near Edinburgh
    246
    Hi, I can take the code that I used for the plugins and write an lscript file. I may have one on another machine already. I'll post the file when I get a chance. I don't have a Mac to make a compiled plugin.
    Regards
    Iain.
    Axes grinder- Dongle #99
    Seattle
    14,230
    Do these plugins just store the data? I mean, except for the exercise, it's just clipart.
    Praise to Buddha! #resist
    May 2006
    Bristol, England
    1,606
    Regards
    Iain.
    Cool! Thanks iain_r. An lscript would be great.
    Oct 2003
    Near Edinburgh
    246
    Lscript teapot file
    Finally managed to get the lscript file created. Used the values from the SDK version that comes with 11. Should work on any version, obviously a lot slower than a compiled plugin while is does all the loops. Added a progress monitor.
    I checked this in 9.6 and 11.
    Regards
    Iain.
    Oct 2003
    Near Edinburgh
    246
    Jeric, what do you mean by "Do these plugins just store the data? I mean, except for the exercise, it's just clipart.". The plugins hold the point and polygon info, I don't know what clipart has to do with this.
    Regards
    Iain.
    Seattle
    14,230
    Store the data, versus create the teapot procedurally.
    If the teapot were created procedurally it would be easy to, say, add more divisions. But if it's a straight collection of points that are joined together poly by poly, adding more divisions would be virtually impossible.
    Still worthwhile for the programming experience. A collection of points is really just a different storage media for clipart, since it can't be altered by the user. Loading the (clipart) object is tantamount to running the plugin, and vice versa.
    May 2006
    Bristol, England
    1,606
    Regards
    Iain.
    Thanks iain_r, works here too.
    It is a little slow and I got a beachball as the progress bar finished, but it made the teapot.
    Thanks for doing this
    Seattle
    14,230
    Lightbulb One click solution for ANY mesh? Generalized 'primitives' generator
    I bet there's plenty of other objects that would be nice to have one-click solutions for. For instance, just now I made a circle, then realized I needed a 'gridded circle'. That's a handy mesh to have access to quickly, and more generally useful than a teapot, I reckon. (And offhand, simply making one manually seems a bit laborious, with a signficant # of points.
    If there were a methodology/script that you could submit a mesh to, and it would spit out a script or plugin that one could add to the menus, users could accumulate their favorite 'primitives'.
    Of course, procedurals would be 'better', BUT a lot of these objects just need to be scaled up/down for a wide range of uses.
    How were the teapot data points entered into the plugin?
    Plugins like this could also make certain workflow practices automatic: I often make a 'Perimeter' point set-- a plugin could include that action. Or the inverse, all points except the perimeter-- whatever works for you.
Name:	gridded circle.jpg
